2005 SAN 210 Keyless Ignition - Gauges come on, won't turn over
  • BrainsBM
    • Sep 2021
    • 4
    • Alabama
    • 2005 SAN 210 TE
    I've got a 2005 Super Air 210 TE and it was running fine earlier today. Just before we got back to the dock, the oil pressure gauge looked low. Took it back to the dock and turned it off and then back on and restarted it and oil pressure read 40 and everything was normal. Turned it off while getting some wakeboard gear and when I went to start it back, all of the gauges would power on and perfect pass comes on but the motor won't turn over to start. It doesn't click or struggle to turn over, just nothing. I hear some noise, I assume fuel pump, but that's it.
    Both batteries are good. I've checked the safety lanyard and looked done a quick look for loose wiring but don't see any. Any tips on what else to check? Thanks!
  • BrainsBM
    • Sep 2021
    • 4
    • Alabama
    • 2005 SAN 210 TE
    I just went to look at it again. Shifted the throttle out of neutral and put it firmly back into neutral and now it fires up just fine. It was locked into neutral initially but doing that helped it. Turns out I'm most of the problem Fingers crossed that was all it was and it'll keep cooperating.
