GS24 Ballst Pressure Sensor Replacement
  • OHLNautique
    • 140
    • TN
    My 2021 GS24 is reading 80% full on the port ballast bag but it is empty. The dealer says it's a bad pressure sensor. They gave me the replacement sensor and a brief description of how to replace it. I have removed all access panels to the bag and I cannot find the sensor. Does anyone on here have any experience working on this system? If so, can you tell me where to locate the sensor?
    Thanks for the help.
  • GMLIII
    • May 2013
    • 2795
    OHLNautique I wish I could help but I got my dealer to replace all three. It is not a project for a weekend boat owner repairman. Even the dealer said they are a PITA to change. Good luck and hope you can locate them
    • Scooter G
      • Jan 2022
      • 1320
      • On a Lake in Idaho
      • 2022 G23 ZZ8
      PM me, I just went through the identical. I'll try to get a post up this week for the community. I found an easy way to do this IMO...
      Engineers should have to work on their own designs.
      • OHLNautique
        • 140
        • TN
        Thanks for the responses but I got it replaced. For anyone that runs across this thread in the future, the sensor is located in the very rear of the bilge in a hole on both sides. You cannot see it but you can follow the fill hose to feel it. To replace the sensor: Remove both of the divider panels between the engine and storage compartment. Unscrew the wire lead then use a 15/16 deep well socket with a swivel joint to loosen the sensor. I then backed it out by hand and screwed the new one in by hand. DO NOT OVERTIGHTEN! Once I had it hand tight I put the socket back on and just barely tightened a little more. Re-attach the wire lead.
        It's a fairly easy job, just hard to get to. If had to do it again it would take me about 30 minutes. Hopefully this will help someone in the future.
        • dbass880
          • Aug 2013
          • 17
          • Stillwater, ok
          • 2020 G23
          Thanks for this info. I'm having the same issue with our G23. I think I'll be able to get replacement sensors from our dealer. Hopefully I can get them changed out.
