Taking on water
  • jkallen21
    • Jan 2013
    • 399
    • United States
    • 2006 Super Air 220
    Taking on water
    We took the boat out for the first time of the season today. I noticed the pump coming on a few times to pump water of the bilge. It’s not a ton of water and the pump clears it easily. But it’s more than has ever happened in years past. I made a video that you can see attached. I took the boat out but left water in the bilge to test.
    I have never changed the rudder packing. Is that the problem here? If so, how hard is it to replace?
    Thanks!
    https://youtube.com/shorts/1Xe-eZy1QsI?feature=share
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Yea, could be the rudder packing. It's a pretty simple fix. Drop the rudder out and clean out all of the old grease both inside the stuffing box and on the rudder shaft. New grease on both and it all back together. If you don't have stainless-steel safety wire, you can use solid-core copper wire.
    -Charles
    • ally505
      • Feb 2012
      • 180
      • Somewhere cold and wet
      • 2008 super air nautique 210, zr6.
      Does your rudder housing have a grease fitting? I'd be inclined to pump fresh grease in the first place, you should see the old grease push out a small hole on the underside. this can help with water ingress issues. But, as above, stripping down and re-greasing and inspecting/replacing the seal is the best option
      if you are getting a lot of rudder movement and steering is stiff, the bearing surface may well be worn, I've had to replace a rudder housing in the past for this very issue.
      • shag
        • 2217
        It could be as above, but if I remember right some boats in that era had poor seems between the hull and deck and were letting water in, especially on turns and if weighted for surfing. It would be along the sides in the rear area of the rub rail.
        • Scooter G
          • Jan 2022
          • 1320
          • On a Lake in Idaho
          • 2022 G23 ZZ8
          Nice video share Kallen, looks like you found your problem. Our last boat had a worn out prop shaft pack, it kept the bilge area nice and clean, lol.
