We have a 2018 Open Bow 200 with a freshwater cooling system (uses coolant). The cooling reservoir is constantly going empty and if we don't keep an eye on it, the engine overheats.
Last summer we took it to our local mechanic and they couldn’t find anything obvious - unfortunately they didn’t have the time to do a deep dive. Last winter we drove 2 hours to our closest Nautique dealer. Reservoirs were backordered so it took 3 months to get anything done. They ended up replacing the reservoir twice and also replacing several (if not all) of the cooling system. They test drove the boat and pronounced it fixed.
I towed the boat home and the boat over heated on it’s first trip. The reservoir was empty….
I was hoping that maybe some air was trapped in the system so we purchased the correct coolant and filled the reservoir as needed. We’ve run the boat 4 hours and used a gallon of coolant - so I’m thinking we still have issues.
I’m headed back to the dealer and they plan to replace the cooling system (again). Does anybody have any suggestions that I could pass along to the dealer? Is this a known problem? Should they be using an air/vac system to replace the coolant?
