sensor connectors
  • gundog
    • Sep 2021
    • 6
    • NH
    • 1997 SN
    sensor connectors
ID:	65275697 SN gt40. How do you disconnect these connectors to the sensors. Is there a special tool? do you have to pry each side or just pull apart. just don't want to break the plastic.
    Also, I did a code scan and I got 11's on both engine running and engine off key on. that's great but I still think i am idling a bit high at 780 to 800. If i tap my tach lens sometimes the tach needle jumps; is that normal? I did check for loose connections behind the tach and all seemed tight.
