2019 G23 Diagnostic Message "Stop Shutdown Engine"
  • jefe
    • 257
    • Orlando, FL
    I have a 2022 G23 with 450 and my temp will slowly start to raise if I have the boat running over 3800RPM. Full Standard Ballast, 50% supplemental ballast. I find the boat works harder on Port side (steering is more difficult). I have 80 hrs and had the impeller changed at 55hrs. I find normal temp is around 170, but she will get to 180 after 10 minutes or so of Surfing. Usually the rider drops/falls, and the temp falls to 167. Not sure if its just this boat, or that it is working harder since I have the supplemental ballast and the cooling system cannot keep up. Water temp here in FL is around 85.
    • Scooter G
      • Jan 2022
      • 1321
      • On a Lake in Idaho
      • 2022 G23 ZZ8
      I found an interesting Moomba thread on engine temps. I will need to pay attention to what temp I am running at going forward, gas - check, subs working - check, speed set - check, temperature - ummm?
      I did order a temperature gun just to mess around with, $20-$30 range, went with a Klein, always seem good quality stuff, they are probably all made by the same place, different label.
      https://forum.moomba.com/showthread....Operating-Temp
      • William_Zane
        • Apr 2021
        • 50
        • Culver, Indiana
        • 2021 Nautique G25
        That is a completely fine operating temp especially under load. Do not be worried until you start to see temps above 200. Not to mention being in FL doesn't help.
