The blower motor originally did not work. When pushing key pad button, i hear faint click but nothing else. Eventually it worked for 3 weeks normal. Now back to original issue. I used voltmeter at motor connection and....nothing. could relay stick. This can not service relay on that breaker box contoler. Any solutions or tests????
Tags: None
It is common for the blower motor to fail intermittently. Are you SURE there is no voltage to the plug?I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
No voltage. The light on key pad also will not come on. I only hear the faint relay click. When I got the boat last year it did not work. I kept pushing the button and it some how worked. I also checked voltage last year and same thing...no V. So could the relay stick...horn was also faint in sound....then started working. Are you saying the motor could be stuck or on a dead spot?
What is that breaker control box called on the sv-211? I had look at it before.. and it has the breaker and relays.. but I don't know if this is the issue or if the relay can be repaired. Any advice will help. I don't want to hear that this circuit board needs complety replaced. It looks expensive and i can not search for it.
