I'm trying to help fix my friend's 2001 Sport Nautique. He tried putting it in the water this last weekend and couldn't get it to start. He thought it was a dead battery, even though it worked when he got it our of storage. They charged the battery and it started, so they put it in the water, and it was dead again. I stopped over tonight to look at it. He had his battery checked after charging it again, and it passed the test. The starter has 12 V at it, and if you jump the relay it cranks, but the dash is dead. If you put the disconnect/power/bilge switch to bilge, the bilge runs. I started with pulling the kick plate out and measured voltage at the breaker box. There's a positive and negative post there. Maybe I was measuring wrong and not getting good contact (it was hard to get to even with the kick plate pulled out a little), but I was seeing 0 volts. Next I pulled the dash out and measured the power going to the port keypad side, and suddenly there was 12 V there. I plugged it back in and the boat started just fine. In between, we were messing around with a few different things, but not sure what we would have done. After the boat started, we messed around again, things like turning the disconnect to off, and the boat stopped working again. Now there is still 12 V to the port side keypad (horn, start switch, etc), but it doesn't work. I also see 12V at teh breaker box on the kick plate now. We also noticed that most of the lights are lit up on the starboard keypad side for things like shower, etc. If you turn the disconnect to off, they turn off, but turn back on when you turn the disconnect back to on. Pushing the buttons doesn't do anything.
I see there is power, ground, and 2 other wires going to each keypad. Are those on a CAN bus? Is there a controller somewhere running them? I've looked at the wiring diagrams on this site, but can't make much sense of what's going on since they are incomplete. The only controller I can find is the PCM one mounted to the engine. Any ideas what's going on here? The only idea I have is the controller is going bad, but don't know if that would be the PCM one on the engine, or if there's another one somewhere else I can't find.
You guys helped me with his positive battery cable corrosion issue a couple years ago, so hoping you can come to the rescue again.
