2014 G21 - Tower Light Not Coming On?
  • Corey Tolle
    • Mar 2021
    • 13
    • St. Louis
    I had to switch out my LED tower light as the old one had a broken mounting plate. The old one didn't work, and I just figured it was bad. After installing the new one, it doesn't work either. I checked all the breakers and no issues, and the tower speaker lights come on just fine (assuming they are on the same circuit as they are operated by the same switch). Any suggestions? For reference, here is the light I am talking about: Tower Light LED, FCT5/Late Model 3s | Nautique Parts
  • Scooter G
    • Jan 2022
    • 1320
    • On a Lake in Idaho
    • 2022 G23 ZZ8
    Start at the source. Are you getting juice to the tower light, check with a test light probe. On my '16 the wire harness runs down the front tower tube on the port side. You may be able to reach the harness plug through some small access holes under the gun rails under the tower mount, check for juice there. Check your breakers.
    Let us know what you find please, and good luck...
    • SatherG230
      • May 2018
      • 83
      • MN
      • 2012 SANTE 230 w/ NSS
      Okay, perhaps I am not understanding your issue, and I am not familiar with the 2016 G23, so that may add to the problem...
      I initially thought you were talking about the tower light that illuminates the interior of the boat, along with the speaker lights, since you mention them being on the same "switch" (I assume via LINC). But, the product link appears to be for the navigation light on the top of the tower (which would be on a totally different switch).
      If you are talking about the under tower light, our 2012 also has a physical switch underneath the tower near the light that went bad. Be sure to check that. If you are talking about the nav light, that should be a different circuit / switch. Like Scooter G said - check for power and follow the wires.
      • Corey Tolle
        • Mar 2021
        • 13
        • St. Louis
        Yes, sorry, I am talking about the nav light. I was thinking that the tower speaker lights (my Roswell's have led rings in them) came on with the same LINC button, but I may be wrong. The boat is back at storage so I can't confirm that at the moment. But it is in fact the LED nav light that is not working.
