Excalibur 330 Oil Drain Location
  • MN Ryan
    • Aug 2020
    • 1266
    • Maple Grove, MN
    • 2007 SV-211 TE
    Can anyone help me with the location of the oil drain tube on an '07 Excalibur 330? According to the PCM manual, you can thread the oil drain hose through the drain plug hole, but I have not yet been able to find it. It appears that the oil was overfilled when I had it winterized last fall, and I'd like to lower the level a bit.
  • charlesml3
    • Jan 2008
    • 2455
    • Lake Gaston, NC
    • 2022 G23
    Should be on the starboard side clipped to a engine lift ring. That said, it could just as easily have been dropped into the bilge. There isn't a lot of room on the SV-211 to reach under there and feel around for it but that's pretty much what you're going to have to do. Take the divider panels out on the starboard side and see if you can reach under there.
    -Charles
    • MN Ryan
      • Aug 2020
      • 1266
      • Maple Grove, MN
      • 2007 SV-211 TE
      Thanks, Charles. You're right, there isn't a ton of room in there, and I'm 6'2". At least I now have a starting point!
      • jmo
        • Mar 2006
        • 710
        • MA
        You can use an oil extraction pump via the dipstick tube to pull out the excess. This will much more precise and frankly faster.
        2018 Ski Nautique 200 TE, H6
        • MN Ryan
          • Aug 2020
          • 1266
          • Maple Grove, MN
          • 2007 SV-211 TE
          Yeah, I would agree. I've been thinking about buying one. Maybe it's time to just bite the bullet.
          • ScooterMcgavin
            • 1478
            • 2014 SAN 210 TE
            They really are very useful, And you can thread it to the drain hose as well for very clean and tidy oil changes.
            1989 Sport Nautique
            • MN Ryan
              • Aug 2020
              • 1266
              • Maple Grove, MN
              • 2007 SV-211 TE
              You guys made the sale. I just bought one.
              • MN Ryan
                • Aug 2020
                • 1266
                • Maple Grove, MN
                • 2007 SV-211 TE
                Alright, using the extractor was slick as snot. Thanks for the nudge in the easy direction!
                • charlesml3
                  • Jan 2008
                  • 2455
                  • Lake Gaston, NC
                  • 2022 G23
                  Do not do this. I've seen more than one extractor tube get stuck in the dipstick tube and require a LOT of work to get it out. There's a very handy, built-in oil drain tube provided by Nautique. Use that instead.
                  -Charles
