2008 SANTE gauges correct daisy chain order
  • wakedork
    • Feb 2009
    • 10
    • Huntsville, Alabama
    Does anyone have the correct order of the diary chain for the gauges. I just bought the boat and it had a bad fuel gauge. Bout a new analog one to replace and going to just hardwire it to the sensor. But after taking the dash apart and unhooking the gas gauge most of the other gauges were loose. Last owner seems to have messed them them and several were just superglued in. So unplugging gauges to fix I thought I remembered the correct sequence but now I am not sure (should have taken a picture). Any help would be appreciated. If memory serves me correct the wire coming from the gateway plugged into the oil pressure guan and not the one the the bigger main gauges, does that sound right?
  • shag
    • 2217
    If daisy chained, and if I remember right - it should not matter the order they're in. You may need to keep the bad gauge connected and maybe hide it behind the dash - in order for the signal to complete the chain. Maybe others will chime in. I know you can check the gauge by just connecting it to another connection.
    Super glue? That's odd
    • wakedork
      • Feb 2009
      • 10
      Yea keeping the bad gauge inline just hiding it. I connected it to another connection but no good. Thanks for the help.
