Fuel sending unit vs Gauge
  • ckevans98
    • Aug 2019
    • 25
    • pittsburgh
    • 2006 super air natique 220
    I have a 2006 sv 22 sante. The fuel gauge is not registering the amount of fuel in the tank. The low fuel warning light does come on though.
    I pulled the sending unit. Slid the float up and down and the gauge did not move. If i put the slide all the way to the bottom the low fuel warning light did come on.
    I am wondering if the sending unit is bad or the gauge. Any help on this mater would be appreciated. !!!
  • biacs
    • Aug 2020
    • 252
    • IL
    • 2006 Nautique 220 Team Edition
    Basically yes it's behaving as if the unit is bad. Check out this video at a 1:30. Set your multimeter to 200 ohms. And test for resistance sliding the float up and down
    https://youtu.be/435kwVAANxU
    I think it's safe to assume if any of these sending units are acting up there probably bad and could easily be replaced
