2006 SANTE BELLY BALLAST TOP Hardware missing? Can someone look at their ski locker?
  • biacs
    • Aug 2020
    • 252
    • IL
    • 2006 Nautique 220 Team Edition
    Crew,
    I pulled my center ballast and fuel tank last week to replace the sending unit for the ballast.
    I’m having some kind of additional water after using the center ballast look in their ski locker and see if I missed bolts or hardware for the top of the tank that would be just inside the ski locker door?
  • 37tr3n5k
    • Mar 2022
    • 60
    • NB, TX
    • 2006 Super Air Nautique 220 TE
    MIne has a hole in the same spot, but when the tank is full, water does not spit out of it. You can hook a fake a lake up to the belly intake hole on the bottom of the boat and fill the ballast to see if its coming out. If it is and you dont need the hole for anything, just plug it with polyurethane. Something like NP1 would last and be flexible. Dont use epoxy since the tank flexes.
