Approaching 1,000 hours
  • pbement
    • Jun 2021
    • 8
    • Clay County, FL
    • 2009 SANTE 210
    Hi, my 2009 Sante 210 is approaching 1000 hours. Anything I should check on, things to look out for or recommended preventative maintenance?
  • Spud
    • Jul 2006
    • 217
    • Echuca Australia
    • 2007 206 limited 2008 206 limited 2007 196 se 2010 200 team
    Just run in!
    • bturner
      • Jun 2019
      • 1571
      • MI
      • 2016 200 Sport Nautique
      Congrats on your milestone. Hopefully you've had the honor of putting most/all of them on yourself.
      If you're looking for more than a check list, I wouldn't hurt to get a second set of eyes on the boat and ask someone to critique the boat for you. Doesn't need to be a dealer and maybe a fellow boater you trust to give you honest advice would be better. I primarily boat in 4 different boats, 3 that are not mine. In each of them I see things that could use a look at or would put on the upgrade list if the boat were mine. You might be surprised what you hear if you're open to hearing about it. Maybe its some wiring, a missing bolt, a gauge that doesn't work all the time or something deeper you can't see the forest from the trees on. I'll use a version of this when I'm flipping a boat or selling a boat I've owned for a long time. It can be somewhat amazing the things someone else may see or notice that you somehow manage to miss.
      Then again if you're looking for a punch list of maintenance items you could go to your maintenance manual and see what they recommend if you're just looking for fluid changes and stuff..... Most likely you'll be directed to inspect/change all the fluids, belts, tensioners, cables, rudder box, hoses, filters, ballast impellers, raw water impeller and very importantly the alignment as well as the strut bearings. Hmmmmm, With the exception of the alignment this sounds a lot like my winterization check list.
        • 16519
        I just bought two Ski Nautiques with nearly 1,000 hours on them. That number of hours doesn't concern me in the least. As long as you have maintained your boat well, just follow the recommendations in the manual and keep on rocking. bturner's ideas above are great too.
        • Nautiquehunter
          • Jun 2008
          • 2080
          The hour meter will probably stop at 999.9 . You will have to add a separate hour meter because there is no fix for the original gauge.
          • shag
            • 2217
            These motors can easily go close to 2000 hours if well maintained. As Nautique Hunter says above, Your hours will probably stop at 999.9
            If you are near your dealer, they 'should' help you out if you take it to them and they can read the hours for you of your ECM. Seems as 2008 into 2009, either correct craft or Faria did not correctly design the Gateway that supplies the gauges. I went through this several times, going all the way to Ron Nace from Nautique and a supposed high level individual at Faria. Nautique says Faria made the mistake of only allowing it to go to 999.9, while Faria insists that Nautique spec'd it that way. Whatever the truth is, apparently Nautique will not allow Faria to even work on these even at customer expense (I tried).
            Enjoy that boat and keep on goin - it will last you a long time with good maintenance.
            • pbement
              • Jun 2021
              • 8
              • Clay County, FL
              • 2009 SANTE 210
              Thank you for this advice. Having a fellow enthusiast is a great idea. I will take another look at the maintenance manual and your winterization checklist.
              • pbement
                • Jun 2021
                • 8
                • Clay County, FL
                • 2009 SANTE 210
                Thank you for the heads up!
                • Rednucleus
                  • Jul 2022
                  • 177
                  • WA
                  Our 2014 nautique 200 club boat is just turning over 4k hours and just getting warmed up!
                  • SilentSeven
                    • Feb 2014
                    • 1855
                    • Bellevue WA
                    • 2004 Nautique 206
                    +1 for putting some eyeballs on your alignment, engine mournts. strut packing, shaft runout inspection, rudder box check, cutlass bearing check. Thats where my 1600 hour 1997 Ski Natuique was starting to show signs of needing some R&R when I sold it for our 206.
                    Bellevue WA
                    • aromeo
                      • Jul 2019
                      • 68
                      • WI
                      • 2002 Ski Nautique w/GT40 2018 Super Air 210
                      Originally posted by Rednucleus View Post
                      Our 2017 nautique 200 club boat is just turning over 4k hours and just getting warmed up!
                      Awesome! What engine is in the boat?
                      • Rednucleus
                        • Jul 2022
                        • 177
                        • WA
                        I know it's a 5.7; I think Excaliber? recently got new exhaust manifolds but otherwise has been pretty rock solid tug.
                        • jpwhit
                          • Aug 2016
                          • 526
                          • Cary, NC
                          My 2012 Nautique 200 with PCM EX343 5.7L is well over 2k and going strong. If well maintained, modern engines can go 4-5k plus no problem.
