Good day and thanks for allowing me to join the forum. Kind of long 1st post but I think needed to see my thinking!
This post is about our 2019 Nautique club boat, private lake use only. Last fall we got a microtuner overcurrent fault that would repeat each time reset. We found the tuner points had been slightly bent causing excess drag in the plate; straightened them and all was well. The fault has recurred; pulled cover off stern and found nice straight tuners. Unhooked from the actuators (each tuner has one) and they slid freely. Reset and went back out w/o tuners hooked to actuators (to isolate motors from hardware) and they deployed correctly several cycles. Then hooked up left side and fault came back - great, that must be a bad actuator! Tried other side by itself, faulted again. Tried both unhooked once again and still got the fault. They are currently staying in the deployed/down position; screen says "microtuners unknown"; also at times says "microtuner error" during our tests. Here's my thinking based on our troubleshooting & my questions:
1. Seems unlikely that both actuators are failing, though possible. Wondering if dealer could read a code showing which is bad since they are on the same circuit, but suspect it doesn't work that way. Maybe by cycling several times in testing we made a weak one cranky?? I could unhook lead to each one to isolate test, but looks like lots of waterproofing on the connection.
2. I assume sensor is a software read vs an actual part that can be tested/changed.
3. For each test we have to put boat on trailer, re-launch and run down lake. I know there's a dealer/demo mode; can we access that so we can run the actuators on the trailer to make trouble shooting easier?
Thanks in advance. I have only found one other brief mention of a microtuner problem in my internet searches, so I assume it's a pretty reliable system.
Red
Red
