I have a 2015 Nautique G25. PCM 550. 228 hours
Issue began about three days ago when the boat would crank from cold start up and then die a few seconds later. I was able to rev in neutral and get to start and run for the whole day without further issues.
On day 2 it did the same thing as day 1. I was able to get it on the water and I seemed to noticed some slight hesitation with getting up to speed and it seems to not hold speed as well through turns. I took it in and took a break and then went out later in the day. While crusing across the lake I lost all power. From that point on I can start the boat and it cranks like normal but dies a few seconds later. I can no longer put in neutral and rev it to get it going.
I have checked the fuel pre filter and replace the FCC inner filter. After the swap I can hear the fuel pump get on before ignition. I have also swapped out both the pump relay and ignition relay. I have also put in fresh gas and checked the batteries with no change. The only code I have ever gotten is when trying to rev the engine at start up I got the "unable to reach higher TPS" error but with a restart I have never gotten this again.
Any help would be greatly appreciated.
