GS22 Shifts Into Reverse With Hard/loud Clunk
  • jameskent
    • Mar 2011
    • 9
    • Missoula, MT
    • Shopping for GS20-22 2008 VTX - Sold 2021
    New 2022 GS22 shifts forward smooth as silk. However, it shifts quite hard into reverse with a loud clunk no matter how softly I try. Is this normal?
  • ESP
    • Feb 2021
    • 25
    • Regina Saskatchewan Cananda
    • 2020 GS22
    I have a 2020 GS22 and it makes a load clunk and ting when put in reverse, I had it checked and they tell me it’s normal. Going to say its normal. I can get video next time were out if you like.
    • jmo
      • Mar 2006
      • 710
      • MA
      If you go between neutral and reverse multiple times in a row (without going forward) does it clunk every time or just the first time? Reason I ask is on one of my older boats I was getting a clunk when going into reverse and it turned out the prop castle nut was a little loose. Once I tightened it, no more clunking.
      2018 Ski Nautique 200 TE, H6
      • jameskent
        • Mar 2011
        • 9
        • Missoula, MT
        Thanks for the info. I will try your suggestions.
        • g21Ryan
          • Aug 2022
          • 10
          • Lake Almanor, CA
          • 2019 G21
          I have a 19 g21 and it does the same thing. I posted about it a month or so ago and it appears normal. It definitely seems out of place. A friends 19 Mastercraft XT22 is smooth as silk in forward and in reverse.. oh well.
          • SANonTellico
            • Aug 2014
            • 301
            • Tellico Lake, TN
            • 2022 GS22
            My 2022 GS22 goes into reverse with no noise and no clunk. It’s perfectly smooth and quiet.
            Previously: 2015 SAN 210
            • Scooter G
              • Jan 2022
              • 1320
              • On a Lake in Idaho
              • 2022 G23 ZZ8
              Definitely a clunk with my G23. Honestly bugs me. I was hoping that the recent replacement of the prop shaft & prop would of given some remedy here. Hearing/thinking/hoping it was normal, but not when others report a smooth transition, maybe not so normal.
              I will be following along here...
              • jameskent
                • Mar 2011
                • 9
                • Missoula, MT
                Based on your responses, it sounds like the luck of the draw whether one shifts hard into reverse or not.
                My dealer indicates they could find no problem during the 25 hour inspection so "it must be normal". Not crazy about that answer.
                Still interested in hearing about anyone else's experience.
                Thanks all.
                • BT
                  • Dec 2008
                  • 77
                  • Alabama
                  • 2012 Super Air 230 1997 Super Sport sold
                  I upgraded from the PCM 40 to PCM 80 series transmission. I think the 80 series is going into most newer boats. The 80 series definitely has a noticeable clunk engaging reverse. Was told it's normal. The 40 series was smooth and quiet up until the time it was replaced.
                  • jpwhit
                    • Aug 2016
                    • 533
                    • Cary, NC
                    80 series does this while they are new when used in a direct drive, but it goes away once the transmission is well broken in - a few hundred hours in our case. In the direct drive, it is cause by a slight shift in the driveshaft when going from forward to reverse. Not sure the behavior would be the same in a v-drive.
