Does anybody have a block diagram of the cooling system for the PCM GT40 5.8 engine? The PCM parts list of the cooling system compoments would also show me the way. The cooling system for the boat includes the thru-hull suction fitting on the bottom of the hull, strainer, raw water pump, thermostat housing on engine, hose routings to port and starboard exhaust manifolds, circulation water pump on engine, cooling hoses to Walters V-drive unit, cooling hoses to heat exchanger for transmission.
Chasing an engine overheating issues and I need to understand the system before just throwing psrts at it. Impellar was replaced and issue returned about 3 hours later. Condemplating replacement of thermostat however, I would like to understand why the engine is overheating.
