Fault code reader for PCM ZR6
  • SG
    • Aug 2021
    • 80
    • Lake Tahoe
    • 2005 SV211 team Previous boat 1989 Ski Nautique (now my sons)
    Does anyone know where to get a code reader for a PCM ZR6? I have a 2005 SV211 that has analog gauges installed because the Gateway box filled with water and shorted out. I pulled up to the dock this morning after wake surfing and when I pushed the start button the starter didn’t engage and the check engine light came on.
    Last edited by SG; 07-21-2022, 12:10 PM. Reason: Update: The throttle lever wasn’t in neutral.
  • SG
    • Aug 2021
    • 80
    • Lake Tahoe
ID:	654649 I found this on skidim.com
    • Go85CJ7
      • May 2020
      • 16
      • VA
      • 05 SV211 TE with ZR6 previous: 93 Excel
      To rule out the simple, did you check the kill switch?
      Sent from my SM-N975U using Tapatalk
      • SG
        • Aug 2021
        • 80
        • Lake Tahoe
        Yes, I did. (I had to be reminded to check it since it is my first boat that actually had one…)
