I noticed that my Port (Red) navigation light isn't turning on last night. The docking lights still work, does anyone know if you can replace the navigation light or do you need to replace the entire light bar? Seems odd that this would stop working on a 3yr old boat. Would this fall to a warranty item (ideally I'd rather just fix it and avoid the hassle of the dealer).
- Apr 2020
- 281
- Basalt, CO
- 2024 SAN G23 2020 SAN G21 (Sold) 2018 SAN G21 (Sold) 2015 Tigé R20 (sold) 1972 MFG Gypsy-15 Tri-hull (sold)
I've had the same (port) nav light go out on both my 2018 and 2020 G21s. In both cases there was heavy condensation in the unit. The nav light and docking light are a single sealed unit. Will be covered by warranty, in both cases my dealer just sent me the replacement and I installed. 5-minute job.
- bob
Old thread but updating it as i have also had multiple port side nav light failures (all port side & nav light only) in 2023-2024 while under warranty
Boat is a 2019 G23.
Port Nav light failed 4 times and had both lighting assemblies replaced 3 times in 9 months. (one time the light stopped lighting, then worked again for a day about a month later, only to stop working again). My lights have seen 0 to less that 2 hours total run time on them when they fail.
Wiring & connectors were in tact, and I have swapped the light assemblies and the issue followed the light assembly, not the wiring.
Test these lights often, to get replacements while you're still under warranty!Last edited by Ckowals1; 3 weeks ago.
