I have a 2006 SANTE 210 that loses power at different times.
I am wondering if the Perfect Pass could be causing the issue. It is turned off, but a beeping typically occurs right before this happens, and it sounds like the PP beep.
Any ideas or suggestions are greatly appreciated.
Mike
- When going over a bigger than average wave, the engine drops to an idle and will not increase speed. You have to shut the engine off and then restart. Works fine after the restart.
- When cruising or towing, after about 45 minutes, the engine starts to slow and then drops to an idle. Shut the engine off and then restart it works fine.
Mike
