2019 Air Nautique fuel pump issue
  • wetskier2000
    • May 2014
    • 30
    • Hudson, NH
    • 64 American Skier 87 Nautique 97 Nautique
    my friend is having a continuing issue with his 2019 Air Nautique (G23?). Dealer says it's 1 of the fuel pump relays. He's been thru multiple dealer installed relays (and related on the water failures) and now they've rewired one of the fuel pump relays outside the relay panel. I don't see anything inherently wrong with this solution, but if the panel itself is the root cause shouldn't Correct Craft be re-engineering the panel/harness and doing a full replacement? Won't other items in that panel have the same issues?
    He said they used the term "Crimp capacity" of the harness as the issue... Unfortunately, I have no idea what that means.... Anyone??
    thanks
