Boat is a 2000 Ski Nautique 196 with 5.8L Carb PCM
Checking to see if there is a trick on how to access the fuel pickup in the main fuel tank (assuming there is something there to check). I opened what I thought was going to be the pickup this weekend but it was only the fuel level gauge. The other two "ports" that I see are pretty well sealed up so being cautious about opening if they aren't the right place.
I'm having some acceleration bogging so going through some basic steps to make sure it's not a clogged / bad filter. I replaced the main fuel / water filter this weekend but made no difference. Appears to be a lean fuel issue at this point which causes a bogging / stall issue. I can ease into the acceleration or back off slightly to recover and then go... at which time it runs perfectly. I have played with the fuel accelerator pump and small adjustments to advance the timing but no notable difference to improve the issue. The Carb is brand new and was ordered direct from PCM. The acceleration bog is exactly as it was with the old carb so replacing made no difference. Fuel pump is fairly cheap so also considering as another next step idea for replacement unless others have other tips to check out?
