Ballast Shift - Stupid Question
  • fwd_loop
    • Jan 2007
    • 35
    • Muskoka
    • 2021 GS22 2007 211TE - Sold
    I have a 2021 GS22. What is the display on the Switchboard supposed to show after you have ballast shifted say 100lbs to the port side? On mine, once the pumps have finished running, the Switchboard display still shows zero. When you go to the ballast display, it does show that 100lbs has been added to the port tank. Is this normal or an issue?
    If normal, its not very intuitive, as I would have thought the Switchboard should show what you have shifted (at a glance), allowing you to add to it or reduce it, as opposed to guessing/trying to remember what the previous shift amount was and then having to make a manual adjustment to increase/decrease (or flipping to the ballast screen to check the difference between the two tank levels and then calculating what delta is). It would also remind you that you have to empty the tank once you are done.
    Let me know what I am missing.
    Thanks
    2021 GS22 - Lovin every minute of it
