Sport Nautique Ballast
  • Arnobowling
    • Aug 2022
    • 8
    • -- N/A --
    • Correct craft 210 sport nautique direct drive
    Hello to you all...I am new to this site because I buy the same one of the year 2002. Can you tell me the size of the back ballast, if you’re familiar with it? I’ve read 50 gallons somewhere, but is it 50:1 or both? Is it possible to install a larger water bag?
    Thank you for your answer!
    Arnaud de France
  • rbalan
    • 328
    • Georgia
    • 2002 SANTE
    It should be close to that. Check out the Model Specification section for details. I would recommend removing the factory tank(s) and replace it with a Wakemakers bag. I’m not familiar with that year, but you should be able to fit around a 70”x 18”x 18” bag (my 2000 sport was roughly this measurement. You will gain a lot of storage when empty and a lot more ballast capacity with the simplicity of 1 tank/bag. You’ll probably need some weight up front as well to keep the nose down.
    • Arnobowling
      • Aug 2022
      • 8
      • -- N/A --
      Hello, thank you for your answer. I’m going to look at how to remove the ballast at the Oem. Do you know if it is complicated to remove and in this case can I connect the new ballast with OEM pumps. Thank you very much
