Hum - High pitch around 5-7MPH
  • Billy2455
    • Jun 2022
    • 15
    • Austin
    • 2016 G23
    Have this sound coming from engine area. Heard different reasonings why but want more options of what it could be. 2016 g23
    Thanks!
  • greggmck
    • Oct 2014
    • 795
    • Bellevue WA
    • 2023 Paragon G23
    It usually means you need to add fluid to the V-drive or transmission.
    • Tom_H
      • Jan 2014
      • 250
      • Minnesota
      If it goes away with a little more speed, might be prop sing. Have you dinged your prop lately or had it reworked? Some prop shops don't square off the trailing edges of the blades when they fix a prop, and a knife edge on the trailing edge will sing at idle. A ding in one of the blades can cause some noise as well.
      • Billy2455
        • Jun 2022
        • 15
        • Austin
        • 2016 G23
        Hey Tom! I did have prop replaced earlier this summer when it got dinged on lake. Old prop was not reworked so this was a new prop. Should they relook at it?
        • Tom_H
          • Jan 2014
          • 250
          • Minnesota
          I'd be surprised if a new prop sung - may want to make sure it's all the way up the taper though. I've seen some jam somewhat on the key on install and not make it all the way on, which I could see sending some hum or vibration up the driveline that may or may not go away with more speed. I'd also check on your transmission/V-drive levels like Greg above mentioned.
          • Kenboat
            • Sep 2021
            • 38
            • Traverse City, Mi
            • Zodiac 5.5 open RIB and 2012 Andy Mapple 200 CB
            Installed my spare prop that was just back from the repair shop. It was the stock prop on a 2012 200 and had pitch added and cleaned up .
            Took the boat out Saturday and it sings like crazy! Will check the transmission level but pretty sure the prop is the cause. I did inspect it when pulled out of water and noticed the tailing edge of the blades has a noticeable turned out edge. Will replace with my other prop and take back the singing prop for inspection.
