Need some guidance from the electronics gurus here for my 2014 SAN 230.
Picked up a used boat, all ran fine for first couple of days. Played around with user settings, ballast fills, cruise control, etc. While cruising the lake day 3, my LINC screen suddenly goes black, motor running fine without a skip. Had trouble cranking to start after taking a break. On a couple of occasions back to the dock, all power shutoff without warning and had to refire the motor.
Google search led me to check the battery switch and it was clearly a failed switch where the plastic backing with battery terminals detached from the front plate. Replaced switch and crank starts without hesitation but still unable to get the “booting…” msg on the Linc. I’ve tried every troubleshooting method found in the internet it seems, like turning power off completely, waiting a few minutes after first hitting Start before hitting Start to crank the motor, holding down the stop button for a few seconds per the manual.
At this point, I am running the boat for weeks without a screen as I can’t get my local dealer to even give me a call back as they have been so jammed. I replaced both batteries to make sure as well. Could the abrupt loss of power due to the failed switch cause something to short? How can I check? Could the alternator have gone bad due to the abrupt power loss? My Polk display inside the glovebox is also dead. I have power in my USB ports however. None of my red fuse buttons look raised as I have tried to push all things resembling a button.
Any ideas on trouble shooting steps? Does the loss of power on both the Linc and Polk radio tell you something I should check and how? Red keypad functional, no backlight for Linc keys. Would a bad alternator cause these issues as well?
