GT-40 Winterization Proceedure
  • fyerfytr
    • Jun 2005
    • 83
    • Des Moines, Iowa
    Well I got the oil changed and used mobil one 0-40 and a Napa gold
    #1515 filter.
    Changed the plug wires.
    Added 16oz of sta-bil
    Ran engine for a few to flush the river water.
    Cleaned strainer bowl.
    Drained the block and the d/c'ed the heater put a small copper pipe between the hoses and blew out core with slow compressed air, tomorrow I will be doing the anti-freeze and ballast tanks etc.
    • M3Fan
      • 1034
      Originally posted by TRBenj
      Originally posted by M3Fan
      I found the low-tox auto antifreeze at Ace. Keep in mind the 10.00 is for un-diluted 1 gallon bottles, so the true yeild is about 2 gallons, so that makes the price more realistic.
      Ahh, I was assuming the low-tox came premixed like the RV antifreeze. That will make it go a little farther.
      Did you pick up some flashing to divert the water away from the carpet when draining the block/manifolds?
      No- I use an old plastic salad bowl to catch the water. Never seen anyone do it with the flashing until I saw your old man do it. Nice trick.
      2000 Ski Nautique GT-40
      2016 SN 200 H5
      www.Fifteenoff.com
      • coloradonautique
        • Sep 2006
        • 98
        • Denver, Colorado
        • 2001 AN 1990 SNCB
        I must of missed the fogging on the GT-40 note in the manual. Dang.. Hopefully I did not screw anything up in the intake since I have already winterized it. Any worries from the board that I will have trouble in the spring? If anything, I imagine I will have to clean out the intake.
        Antifreeze: I use the bio-safe -50 degree stuff from West Marine. Not sure if it is the same stuff as the RV but it is what I have used in all my boats (sailboats included). They make -60 and -100 that you can dilute but the pre-diluted -50 is just easier to work with. I think it was $6-$8 a bottle.
        ___________________
        2001 Air <-- New boat
        1991 Ski <-- Old boat
        Denver, CO
        • rotorcom
          • 12
          • Boise, Idaho
          Good suggestions on winterizing. I have never heard anything bad about Fram oil filters until I read these posts.
          what's wrong with them? I seemed to have missed any previous articles written about them. Thanks.
          • jmo
            • Mar 2006
            • 710
            • MA
            Here is one article I came across while trying to research this topic - scroll down to the section of "filters to avoid"
            http://minimopar.knizefamily.net/oilfilters.html
            2018 Ski Nautique 200 TE, H6
            • Fast351
              • Oct 2006
              • 315
              • Winsted, MN
              • 2001 Ski Nautique
              #21
              A VERY interesting page regarding different brands of oil filters:
              http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
              I will second the Motorcraft oil filter for Ford small blocks. I've cut apart a number of different brands (I cut every filter apart to look for weird wear on my race engines) and the Motorcraft is one of the best built filters.
              2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
              • kutcht1
                • Aug 2006
                • 8
                #22
                Ok, I did this on my 1998 Air for this first time and only found one engine block drain **** on the port side. Is this all there is for the block?
                TomK
                1998 Air Nautique – current boat
                1986 Supra TS6m – previous boat
                1973 Martinique – previous boat
                • jmo
                  • Mar 2006
                  • 710
                  • MA
                  #23
                  TomK
                  I have a (model year) 2001 GT-40 engine and it has 5 drain main plugs:
                  2 on the bottom of the block (one on each side) standard 3/8"
                  2 exhaust manifold plugs (large ~ 1"diameter plugs)
                  1 on the bottom of the housing that contains the thermostat (y junction water hose connector) standard 3/8"
                  and a 6th if you include the one on the bottom of the fuel filter cannister (you will dump out a cup of fuel in the process so don't let it dump into the bilge).
                  plus 7 & 8 on the v-drive gear box - small plugs with a square head.
                  I can't image the 1998 would be any different, but check your manual.
                  • MNSuperAir
                    • Sep 2005
                    • 591
                    • St Paul
                    • 2016 SAN 210
                    #24
                    You can also call skidim.com. They are very helpful with what is required and where the plugs are on the different engines
                    2016 SAN 210
                    2006 SANTE sold
                    2001 SAN - sold
                    1991 Sport Nautique - sold
                    • kutcht1
                      • Aug 2006
                      • 8
                      #25
                      Well, I did see a hole above the starter which looked like there should be a drain there but there wasn't. I however did fill with 50- antifreeze.
                      One additional question, even though we didn't end up using the heater this year, does water still get circulated through that system? I didn't disconnect those hoses and blow them out. I did after all was done fill with the antifreeze. It should be ok, right?
                      Thanks.
                      TomK
                      • TRBenj
                        • 1681
                        • NWCT
                        #26
                        If you got the water out of the core before it froze, then you should be OK. After I backfill the motor with antifreeze, I blow out the heater core then fill it with A/F through one hose until it comes out the other.
                        1990 Ski Nautique
                        NWCT
                        • air210man
                          • Nov 2006
                          • 4
                          • MI
                          #27
                          what is the best way to fog the motor, how is everybody doing it?
                          • jedgell
                            • 170
                            • Bozeman, MT
                            • 2004 SN 196
                            #28
                            I sprayed the fogging oil into each cylinder. Remove plugs, spray oil for 3 seconds, install plug. If you have the GT-40 don't spray it into the intake.
                            \'95 SN Signature Ed.
                            GT-40
                            PP Stargaze
                            **For Sale**
                            • air210man
                              • Nov 2006
                              • 4
                              • MI
                              #29
                              spraying the fogging oil through the PCV valve (not intake) is much easer while adding a/f through trans cooler at same time, check for a/f on at all drain plugs by loosing them, also spray fogging oil on shifting arm where it goes into the trans is good too.
                              • fyerfytr
                                • Jun 2005
                                • 83
                                • Des Moines, Iowa
                                #30
                                Good point - I did the shifting arm with the fog oil also...
                                Mark
