Has anyone run across these messages on their Super Air Nautique? I have finally got most of my gauges working on the boat. My boat has 279hrs on it, oil pressure works on the tach digital display, voltage displays correctly, Engine temp rolls back correctly but goes up to 139 degrees when running on both my digital display and the normal gauge. Someone has replaced my oil pressure gauge and it does not display on the normal gauge but works on the digital display.
My question is has anyone had these 3 messages at the same time and what did they do to remedy the situation? Thanks in advance. I am still looking for a factory oil pressure gauge working or not if anyone has one.
Additional information, the boat is running rich and wants to cut off if you pull it back to idle quickly and runs rough around 1500 RPMs unless you are accelerating through at a higher rate. I’m thinking it may be the ECU?
items thrown at it so far:
plugs, wires, rotor, cap, low pressure fuel pump, high pressure fuel pump, coil, TPS, idle air sensor, cleaned fuel injectors (thanks for the 9v battery trick), fcc filter, added a fuel filter in line between the tank and the low pressure fuel pump, cleaned anti siphon valve on the tank and blew out all vent lines
