OK water testing the new resto and this engine hasn't run in 1 year. EECIV of course, and I think it's a quality system for its day!
Symptoms:
Vibration at idle and puttering around.
Moving onto plane, rough/chugging feel at 800-1200 RPM. This is the worst zone
After 1200-2500 not too bad, still a miss or two.
2500+ sustained running I can feel drop-offs. Enough that I don't want to ski it.
I can go WOT, will get to about 65 Kph-ish but still having those dead spots, (feels like a slalom skier pulling on the boat for 2 secs at at time).
Boy I miss that solid power!
History:
1. Didn't start in July so changed the FCC filter found a lot of rust and pump had jammed. Cleaned it all up, new filter unjammed the pump and looks OK
2. Fuel pressure is around 35 PSI, peaks at 40 PSI when throttle is cracked. Running around the lake, pressure is stable say 32-36
3. ECT ACT Sensors are OK. Power seems to be good to relays etc.
4. Had an air leak at the idle control solenoid, fixed that & running a bit better.
NO codes, reader returns an 11 all systems good. Distributor cap, rotor, plugs, wires are recent/ new.
The distributor bowl is pretty rusty so cleaned that up but no change in operation whatsoever.
Usually I am pretty good at these things, but this one has me a bit stumped.
Leaning toward fuel (injectors?) but can be convinced to try otherwise.
The engine did bog/recover sometimes when hitting it with a skier for the past few years. This was a bad thing for beginners.
thx,
Symptoms:
History:
thx,
