2010 210 fuel gauge not working
  • hyperlitep
    • Sep 2012
    • 82
    • Wenatchee WA
    • 2010 210 TE Previous boats:2005 Ski 206 LE 1991 American Skier
    Ok I have posted here before about this and never really got any advice. I have a 2010 210 with linc 1.0 my fuel gauge has never worked right since I bought the boat. I have replaced the sender and checked all grounds, I even ran a dedicated ground just for the sender to see if that solved my issues. When I accessory on my boat the fuel gauge typically works. If I start the boat gauge goes to just above or below half tank and stays there does not move. Any insight or info would be helpful, it is very annoying to have a non functioning fuel gauge. Thanks
  • shag
    • 2217
    So you replaced the actual 'in tank' piece? I would think if it is sending a signal and you are getting some function, that maybe the in tank float is the issue. I can't remember if that 2010 has individual fuel gauge or if it is in the linc screen.
    • hyperlitep
      • Sep 2012
      • 82
      • Wenatchee WA
      Float is part of the sending unit in the tank. Fuel gauge is in the linc screen.
