Our 2008 Nautique 206 has a light vibration. Prop is ACME 422
There is a small amount if play in the strut. Steering feel stiff as well. Shaft packing dripping way too much. Rear bilge needs replacing. Belly ballast pump not working.
So here is there service plan
Remove prop. Have prop reconditioned for spare and by new to use
Remove rudder. Clean, repack when reinstall
Remove shaft. Check shaft to be correct, straight, and free from excessive wear
Replace strut bearing (is that one 6in bearing, ITEM NO. S1095 STRUT BEARING FOR 1″ SHAFTS)
Reinstall shaft. Should be no play at strut with new bearing
Check alignment
Repack shaft stuffing box
Reinstall rudder. Clean and replace rudder packing. Lube where possible. Check steering for ease of use
Replace bilge and ballast fill pump as needed
Reinstall fuel and ballast tanks, deck panels, seat
This sound about correct? As a shade tree guy, there will be questions... but it all seems pretty standard servicing.
or send to shop... just not crazy about that bill... guess is 2500 to 3500. Any idea on cost if at shop?
Check alignment
