Analog Temp gauge reading high
  • sjk
    • Aug 2006
    • 16
    • Granite Bay, CA
    Anyone have any experiences with a Analog Faria Temperature gauge reading hot ~190degrees when the engine is running normal (158 degrees)? This is on a 2006 196.[/b]
  • j2nh
    • Dec 2003
    • 628
    • Spread Eagle Wisconsin
    Curious.
    How do you know that the temp guage is reading hot?
    Which engine?
    Is it always reading hot?
    2018 200 Team H6
    2009 196 Team ZR 409
    2005 196 Limited ZR 375
    2003 196 Limited Excalibur
    1999 196 Masters Edition
    1987 ProStar 190
      There is a specification for the resistance of the temp sender. I do not know what is is, off the top of my head. Temporarily remove the wire from the sender on the engine, and check the resistance to ground. It will change as your engine warms up. You should not turn your engine on with the sender disconnected, it will set a trouble code in your engine computer. With the key off, disconnect the sender, and check the resistance. reconnect the sender, run the motor, turn the motor off, disconnect the sender, and check the resistance again. Compare that information to the specs you found for your motor.
      • sjk
        • Aug 2006
        • 16
        • Granite Bay, CA
        Temp
        My local mechanic plugged is laptop into what I assume was the sender to get the actual temp. Yes. after running for a bit the gauge always runs up to around 190. Engine is an Excalibur
        • skinautique
          • 1749
          • Colorado
          RE: Temp
          it might be a faulty gauge. did he plug a new gauge in?
          • sjk
            • Aug 2006
            • 16
            • Granite Bay, CA
            No, I'll have to take it in to West Coast Correct Craft for that to get it covered under warranty. He suspected it was either the gauge or something in the electronics.
              I would go to WCCC, If I was not confidant in what I was doing. They are good, knowlegble people.
