gluing seadek back down....
  • gscho002
    • May 2014
    • 109
    • baltimore
    • 2010 SANTE 210
    hi everyone
    so the corner of one of the SeaDek panels on my swim platform is de-adhering bit. i'm wondering if there is an approved method or glue to use to re-adhere it to the platform......
    i actually installed SeaDek in the boat a couple years ago. worked great. but i did NOT replace what was on the platform. this means i have those pieces and could replace. but it seems like ti will be a huge pain to take it all off properly. seems simpler to just try to spot-glue this back on????
    any suggestions before i try superglue, contact cement, or some other obvious solution?
    thx in advance,
    geoff
  • Lakejackson
    • May 2012
    • 160
    • Lake
    • 2011 Sport 200
    I've used 3M spray 90 several times with no issues. Since it is a spray you have to tape everything off and it takes some practice to get good at applying the correct amount.
    • shag
      • 2217
      3M spray 90 here also. Get as much of old adhesive off as you can.. I used 90% rubbing alcohol to prep surface for better adhesion
      • gscho002
        • May 2014
        • 109
        • baltimore
        • 2010 SANTE 210
        thanks everyone!
        • Scooter G
          • Jan 2022
          • 1329
          • On a Lake in Idaho
          • 2022 G23 ZZ8
          Ditto on the 3m spray, looks like you found the magic. Let it tack for a few minutes and then stick it down, watch the overspray.
