There are attachment points on the Ram-Lin trailer for transom tie downs but no specific transom tie down points mounted onto the transom of my boat. Where, if ever installed, did Correct Craft put them or is one simply supposed to hook the upper end of the transom tie down straps/hooks to the swim grid supports?
Agreed. Swim platform brackets are what I use too.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I had a buddy comment the other day, are you sure that's the right place to hook the straps? Pretty freakin' solid my man, those swim deck brackets aren't going anywhere. After he took a closer look he said, "oh ya, you're right".
I have an 2001 Air, would the swim platform brackets be the same advise others would give for my boat?
Yes. That's even what we use on the G-series boats.
Someone mentioned this to me years ago, and I had never thought about it, but I realized that it is true. The tie down points and straps only need to be strong enough to lift the weight of the trailer, not the boat. the point of the tie downs is to keep the trailer attached to the boat, not the other way around.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
