H6 thermostat gasket orientation
  • jmo
    • Mar 2006
    • 710
    • MA
    Hi guys, putting in a new thermostat in my 200 with the H6 motor, and the new one came with a housing gasket with a rubber bead on one side. Which way do I orient it when I put it in. There wasn’t a gasket in there when I took the old one out - it just had the black rubber o-ring around the thermostat itself. Mine is raw water cooled.
    thanks
    2018 Ski Nautique 200 TE, H6
  • jmo
    • Mar 2006
    • 710
    • MA
    According to my local Nautique service dept, on the H6 engine you don’t use the paper gasket that’s included with the replacement - the o-ring on the thermostat itself is sufficient.
