For a PCM zr6 390hp (2007)
The hoses that go from the bottom of the engine to the oil filter started leaking so I decided to change them. One hose connects at the bottom of the engine and one hose connects a little bit above, both on the starboard side. The hoses then connect to the oil filter on top of the engine on the port side. One to the peripheral holes in the filter and one to the central hole. The problem is I forgot which hose went where. Are there any clear instructions as to which oil connection at the bottom of the engine goes to which connection to the oil filter.
