Was on rhe watee today and Linc screen went black. Everything still works. Ideas? Pic is actually from today before it went black.
I would inspect the main power line and or inline post fuse coming off the battery selector switch. Power to the motor and linc computer split right after the selector. That was the culprit on my boat.
So after disconnecting battery and rebooting everything, somehow when I turned the navigation lights on the keypad the screen came on. Turn nav lights off and screen goes black again. Had no idea keypad could affect the linc screen. Anyway, shut everything down again while nav lights were on, restarted and everything works normal again. Go figure.
update: dealer thinks it is a short with the keypad. When i turn nav lights off on keypad, screen goes black. Turn nav lights back on, screen comes back on.
Originally posted by 2016SPORTNAUTIQUE200 View Postwhen I turned the navigation lights on the keypad the screen came on. Turn nav lights off and screen goes black again.
-Charles
Brightness is all the way up. Last time dealer had it they programmed Linc to a 21 model so reprogrammed back to 2016 Sport and it corrected surf system which it does not have. I passed on fixing since they want $600 and its not affecting anything currently. Just annoying.
Neutral to rev engine not working either. They want $900 to fix this as you have to buy entire throttle assembly to fix. Passed on it. Dont need neutral rev that bad.
...I think this is why I'm never getting a newer boat. These aging e-systems are brutal.2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
Mine is doing the same on the neutral rev intermittently. I keep thinking about doing it and may still. ~$600 for the part and I'm told it's fairly easy to do which I would have to think it is if your dealer is only charging you ~$200 to install......
https://nautiqueparts.com/throttle-b...and-sport-200/
