Hi! Any of you has installed an electronic conversion kit for there 351 ford distributor to replaced the points, Pertronic, Hot Spark?
- Jun 2016
- 541
- Ft Worth, TX
- 2022 G23, Previous: 2021 GS24, 2011 Super Air Nautique 230, 1995 Super Sport, 1983 Ski Nautique
I’ve done it. Make sure to pay attention to the wiring. Your coil probably wants a ballast resistor. The distributor module will almost certainly want full voltage. You’ll also need to find a good ground for the module. (The alternator ground is a good spot.) But I am curious why you’re doing the swap. If you’re doing it to fix an issue you may want to make sure the points are the issue. I did mine and found out the problem wasn’t my points. It was the 30+ year old springs that expand EVERY time the engine was ever revved. They were just worn out and I couldn’t get the timing right at base and advance. The springs were harder to find than a new Mallory so I did that instead after spending $80 on the Pertronix module.
RTFM my friend. Hal has it right. You need to do a ground check between the distributor and the battery. You need to understand your current ignition voltages at the coil and where/how you plan on getting 12 volts to the module. If you go to 12 volts for the coil you'll probably need to get a different coil to get the most out of the conversion. You'll also need to re-gap the plugs wider with the hotter coil. Or just throw it in and see what happens.....
It's a fairly simple conversion but there are ways to screw the pooch if you try hard enough or not at all.
Remember the 5 P's (Proper Planning Prevents Poor Performance). Do some research or just call Pertronix support and talk to them.
- Jun 2008
- 2080
- Flowery Branch GA Lake Lanier
- 2008 210 SANTE 67 Correct Craft Mustang
Do yourself a favor install a DUI distributor and never look back
- Jun 2016
- 541
- Ft Worth, TX
Yeah, I’d just leave it as is. Good reasons to go from points to electronic: don’t want to bother setting dwell once per year. Bad reasons to go from points to electronic: anything else.
- Aug 2014
- 370
- Salt Lake City, Utah via Texas
- 2003 Ski Nautique 206 Limited with ZR6 Engine
DUI (Davis Unified Ignition) at Performance Distributors is the way to go. The HEI style dizzy is a 2-wire hook-up with no ballast resistor. The DUI is the only dizzy I would install in SBC / SBF marine applications requiring a traditional distributor.
JQ
