1987 SN 2001 w/ Ford 351. Last season started getting warm/hot at idle, but seemed to cool off with gentle throttle and ran fine/cool while under load/skiiing. Replaced the impeller. No change. Emptied/flushed water jacket. No change. No water in the oil. Bad water pump? Bad thermostat? Thoughts/suggestions?
Check the exhaust risers and manifolds. If they are full of rust on the inside, that can be a cause of running hot.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Check for air leaks between the suction side of the raw pump and the water intake hull fitting. That typically includes the strainer (if you have one) and the transmission cooler. That part of the cooling system is under negative pressure, so water doesn't leak out, rather air leaks in. The air will displace too much cooling water at idle. Engine will cool down when the RPM is higher and more water is flowing.
