Hi all,
Over the winter I had taken the computer modules in harnesses loose to get the valve covers off to replace valve cover gaskets.
Been running the boat on the hose here and my tach seems to essentially display no data as far as RPM on the needle or engine temp/engine hour data on the digital readout.
In some Google searches, I found a similar reference to a particular cable being disconnected on someone’s harness near the throttle linkage.
And after my gasket install this winter, I noticed I have this plug still laying on top with no male plug into. Is this just diagnostic? or do I need to hunt down the male end of a harness pushed under something?
