2003 196 Gas Fill Size
  • Interjon
    • Dec 2019
    • 136
    • Alabama
    • 2003 196 2019 SN200
    I have several of the Flo-Fast gas tanks and discovered that the hose I use for recent model Nautiques does not fit in the old style fuel fill, including the one on a 2003 196. Does anyone know the size (or can check for me) of the "old" style fill (meaning the largest outside diameter hose I can use)?
    Thanks. I had to rig something up with a funnel to get gas in.
  • JayG80
    • Dec 2006
    • 206
    • Santa Fe, TX
    • 2007 Ski Nautique Sold 2002 Ski Nautique
    My 2007 seems to be the same as my 02. I use a hose jiggler with 7/8” outside diameter. There is a little wiggle room, actual opening may be 1” but I can’t get an accurate measurement since it is recessed
    • Interjon
      • Dec 2019
      • 136
      • Alabama
      Thanks for that JayG80. I also found out that the US standard for fuel nozzles, at gas stations for unleaded, is 7/8 OD.
      • srock
        • Oct 2008
        • 1066
        I had to add a reducer and nipple to my fast-flow hunsaker gas cans so it would fit my 2009 boat. Fueling from cans is a much slower process now.
