Ballast gauges
  • Gregm
    • Sep 2022
    • 8
    • TX
    • 2004 210 te
    Ballast gauges
    I had the gateway bypas done over the winter and I just took the boat out last weekend and now none of the ballast gauges are working. I called the dealership and they said that those gauges are not a part of the gateway system and were not messed with during the process. Could some cable have come loose or something like a ground cable? They all worked last year and now they all read 0 all the time. Any suggestions??
    thanks!!
  • biacs
    • Aug 2020
    • 267
    • Lake Benson
    • Raleigh, NC
    • 2006 Nautique 220 Team Edition
    check the pump fuses- in the back panel by battery switch.
    • Gregm
      • Sep 2022
      • 8
      • TX
      • 2004 210 te
      The pumps are working fine and filling the tanks but the gauges will all just stay at 0
      • biacs
        • Aug 2020
        • 267
        • Lake Benson
        • Raleigh, NC
        You need the gauges working in order to tell the pumps to drain. Take a small piece of wire, snip off a little from each end to make a U-shaped, and jump the harness connection at the ballast pump to see if the gauges flip up to full.
        its not uncommon for these sending units to go dead and not read. So you can test each gauge by jumping the connection at the sending unit to see if the gauge goes full.
        If a couple of the gauges unresponsive when you jump, the harness, you can start checking the wiring
        • Jhinkle976
          • Jun 2022
          • 3
          • Discovery Bay
          Possibly the ballast sending unit
          • MN Ryan
            • Aug 2020
            • 1384
            • Maple Grove, MN
            • 2007 SV-211 TE
            That depends on the boat. My '07 has timers on the pumps--works fine with the gauges disconnected.
