The codemate works on all MEFI-4 compatible boats. They sell various adapters. This table looks like yours is a MEFI-4 but PCM/Nautique can probably tell you for certain: https://www.rinda.com/acro/Engine_Support_2023.pdf
Considering myself lucky today... issue was corrected by replacing the Water Temp Sender (# R020019). It's not often that the easiest to access and cheapest of the potential fixes turns out to be the fix. Thanks again to all for your interest and help!
Of note the gauge and idiot lights typically have separate sending units so when a light comes the first glance should be the gauges as a confirmation. I will also comment on your battery age note. Electrical issues related to batteries, alternators, and loose wires can create the strangest symptoms that are easily resolved.
