Good afternoon.
I have a 2008 SAN 220 with the Zero Off speed control.
Current Issue-LCD screen problems
-When I turn the boat on auxiliary the Zero Off comes on fine, but when i crank the boat up the zero of starts getting darker (as in too many pixles start showing)
-When you run the boat at idle the screen turns grey-ish, but as you get on the throttle it gets darker and eventually goes black (not blank)
NOTE- the speed control still works and kicks in at the desired speed, bit I just can't see that speed or any other info on the LCD screen.
Anyone have this issue before?
