Ok guys I need a little help. A buddy of mine is a crossover rider, and is looking at the 211. I wanted to see if anyone had pictures of the wake in "ski" & "wakeboard" mode. Thanks!
Tags: None
RE: 211 Wakes
Fatboy posted some pictures of this sometime back. Do a search and I'm sure you'll find it.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
RE: 211 Wakes
Click away, everything you could learn about a 211 without a test ride is contained in the following threads:
http://www.planetnautique.com/index....pic&t=7110
http://www.planetnautique.com/index....pic&t=7100
http://www.planetnautique.com/index....pic&t=7032
http://www.planetnautique.com/index....pic&t=6874
http://www.planetnautique.com/index....pic&t=6710
By the way, I feel pictures of wakes are usually very misleading.
the hydrogate is pretty cool...it will shape the wake.. i would suggest getting behind to try it..depending on where you live, i would look to be a 3rd for a day and find out first hand (hopefully they will weigh it down for wakeboardng/wakesurfing)..
in regards to the 211. alot will do with how you weigh the boat...everyone does it bit different. i got my wakeboard wake"close" to the 210.. the 211 is a bit wider but the 210 still has that little bit of extra kick... for wakesurfing, the 211 is much better due to hydrogate and bigger swim platform.
if you are looking for a good wakeboard wake and surfwake( it is really good with a little bit of extra weight)..
for skiing, i have never acheived that "flat table" like a ski boat(a buddies 210 did much better imo - it could have been that extra lead i had in the boat though my ballast was drained... however the 211 is a little porker when it comes to weight despite being a 21' boat.
