replacing LED on 2014 g23
  • gaprea
    • May 2022
    • 2
    • Clay, Mi
    • 2014 G23 409
    Anyone ever replace those small circular LED's? two oof mine stopped working... I ordered new ones (2 wire version)
  • MN Ryan
    • Aug 2020
    • 1366
    • Maple Grove, MN
    • 2007 SV-211 TE
    I assume you're talking about the little, round courtesy lights. Mine are older, but I would imagine they're not that different. I had one that was out--I went to replace it and discovered that it was just a loose connection. They should be fairly robust LEDs, so perhaps yours are the same problem.
    • gaprea
      • May 2022
      • 2
      • Clay, Mi
      • 2014 G23 409
      Thank MN Ryan that's what I was thinking... LED's are pretty tough I guess I'll check the connections first.
      • MN Ryan
        • Aug 2020
        • 1366
        • Maple Grove, MN
        • 2007 SV-211 TE
        Yeah, I popped mine out and found the problem instantly. Quick and free fix--I like those! Good luck to you!
        • BasaltRMK
          • Apr 2020
          • 310
          • Basalt, CO
          • 2024 SAN G23 2020 SAN G21 (Sold) 2018 SAN G21 (Sold) 2015 Tigé R20 (sold) 1972 MFG Gypsy-15 Tri-hull (sold)
          I replaced the two rear courtesy lights by the walkthrough near the rear built-in cooler. I replaced the stock white ones with RGBs, had to do a little rewiring as well (for some reason these are the only two white courtesy lights as opposed to RGBs). It was a piece of cake. There are two push tabs on the back side of the light, and there was also double-stick tape on the front side below the chrome collar. I reached in the back to push in the push tabs, and gently pried up from the front with a plastic scraper.
          Let me know if you need any help, I probably have some pictures squirreled away. Good luck!
          - bob
