'07 SV211TE. I get a fair amount of water in the bilge when surfing. I can leave the boat in the water overnight or run around/ski (unweighted) all day and it stays completely dry, so I'm pretty sure it's not a through-hull fitting issue. This spring, I removed the rear portion of the rub rail and sealed any gaps with 3M 5200. That didn't seem to improve it. My only thought now is that water is getting in through the rear vents--they sit pretty low when weighted, and spray from a wake shaper, etc...
1) Anything I could be overlooking?
2) Any ideas to mitigate this? I assume the vents are necessary.
