2022 G23 Won’t even show signs of life
  • Lake Carlos Marina
    • Feb 2023
    • 1
    • Dallas
    • 2022 G23 1985 Ski Supreme
    You ever have your G not start?
    Not even make a sound?
    The little blue lights around the buttons come on for about 10 seconds and that’s it.
    I’ve tested the batteries on this thing (13 volts each). Checked all the connections, fuses and wires. Everything is tight​. Boats in neutral, dead man switch is good…
    I don’t know what else to do.
  • vision
    • 517
    • NC
    • 2013 G23
    Does the battery selector switch turn normally? I had a bad battery switch cause similar issues. There is also an inline fuse on the battery selector switch (on the positive post on back side of the selector) that if it goes bad no power goes the the Linc.
    • jpwhit
      • Aug 2016
      • 526
      • Cary, NC
      Could be a failed Throttle Base Assembly. The common failure scenario is the TBA fails in such a way that the computer is getting a signal that the boat is in gear and disable the ability to start the engine.
      • Scooter G
        • Jan 2022
        • 1320
        • On a Lake in Idaho
        • 2022 G23 ZZ8
        vision has something for you there.
        You would still have normal functions, other than start with a bad TBA, I know this because I just homeworked to the end of the internet on this, last page said "the end". lol.
