Hello, first time anchoring out this season. I skied earlier that day (crack of dawn) with no issues. Later that day after lunch took the boat back our, it was driven a short distance about a mile or so to anchor out. When I cranked the engine up 3 hours later, the boat temp was reading 212, I moved in slow gear for about 50 yards to clear the boats also anchored out, and took off heading back to the boat landing, almost immediately the fresh water coming in brought the temp down to where it normally reads around 150. The boat is a 2009 and the first time seeing a high temp after it was just sitting with the engine off for several hours. Should this be a concern at this point. I live in Georgia air temp was 80 that day and water temp is still in the low 70's, so a very mild day. If any suggestion on what I should do next, i have ordered a new impeller, as it has been 2 years since i changed it last. Thank you in advance
A d m i n i s t r a t o r
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
Probably not a concern. With the engine sitting after having been run, the water inside will heat up since it isn't moving. Once the flow starts again, it cools down.
Replacing the impeller isn't a bad idea. I'd just keep an eye on it and see how it behaves once that's done.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
If it's hot at idle, but cools to normal at higher speeds, then you should check the sea strainer. Even the tiniest leak / drip from the strainer will result in this condition.Previous boats:
2015 G23
2008 SAN 210
2002 XStar
1995 Sport Nautique
